Coilover adjustments
OneJArpus
2,798
I have a question about coilover adjustments.
I have KSport coil overs and i'm just trying to figure out what is the best way to adjust the ride height of the vehicle.
Should i adjust it from the body? (lower part) or the springs
What are the advantages and disadvantages of both if i could do one or the other. Thanks
Mine look like the one to the left
Reference pic (Tein Flex) same design.
Wiisass
Set spring preload at about zero all around, just enough preload to hold the spring in place with the shock unloaded. And then set height with the lower mount. If you need to go lower, then you can look at using the spring perch, but I doubt you will need to.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
adding perload just useless i tried it befor on some spring's you get more spring rate some same you have no change no perload makes it boncey and stiff ish
i have all wasy whent tell snug and ran cushin spring for rough roads
not all coilovers will come with custion spring's thou
makaveli913
1jz and lovin it
Nov 20, 2007
135
Pueblo Co
Does anybody have a adjustment wrench for the older teins? I need the long hook wrench thing. My rear is REALLY low and i need to Higher it to put some new rims on. PLEASE CAN SOMEBODY HELP????
Grimsta
1,081
Santa Rosa, Ca.
If you add preload, you're pre compressing your spring and eliminating a certain amount of travel in the spring. You should lower the shock body before reducing the amount your spring can compress
However, if you're as low as my Supra is you need ALOT of preload in the front to keep from rubbing the wheel.
