codes won't clear...
rakkasan
Currahee!!
Fort Campbell, KY
drjonez said:
depends on the code.
also depends on what you have wired in, remember it is possible to backfeed the ECU w/power if you hooked up an external device improperly.
I'll try disconnecting the battery, because I'm still getting a code 21 after putting a 1k resistor between my wideband & the ecu. My A/F is perfect now instead of it jumping around like it had, so I'm fairly certain that it shouldn't throw a code now.....
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
super.secret.supra.club said:
yes...the problems still exist.
I meant that there is a possibility of the mechanical problem still existing,which is why the code wont clear. I may be wrong, someone correct me if I am.
