Code 43 - starter signal
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I'm not sure why I'm getting this code, but I was wondering if it might be a part of my problem of being hard to start when cold.
Does the ECU give the engine more fuel or fire up the cold start injector when starting? How important is this signal?
Can I simply run a wire from the ignition start switch directly to the ECU? Does it just need a 12v signal?
I can start the car without pushing in the clutch, and I checked the bottom clutch switch and it is connected and works fine, so I'm not sure about that part of the circuit.
jetjock
creepy-ass cracka
9,439
You're getting the code because ECU input STA is not going high when the key is held to start and yes, it will cause cold start issues.
It's important. You'd be surprised to learn what the TCCS does with that signal. For example it fires all 6 injectors at once during a start. STA is also used to power the cold start injector.
You could but since that's what the stock wiring does why not fix it?
You should fix that too...
