Code 35?
boosted17
235
Florence, KY
My check engine light is on and it is giving me a code 35. I have an 89 supra turbo 5spd swap. In the manual it says this is the Hac sensor signal. From searching on here it I have found out that this is in the ecu. My question is how do I fix this error code? Is there a sensor that reads the HAC? :1zhelp:
Thanks
boosted17
235
Florence, KY
Also my car is a auto to 5spd swap. I have am using a auto ecu. I also have a 5spd ecu. Should I swap them out. With this affect my apex neo settings?
You can use an *auto harness* with a 5 speed ECU, but not a *5 speed harness* with an auto ECU. If you have a 5 speed and auto harness, you should be using a 5 speed ECU...the year (same color plugs) has to match. ;)
