so the car is a 89t stock except for there is no exhaust after the downpipe.
code 34 is abnormal boost pressure
the car will not tolerate any kind of boost it immediately stutters
its very hard to get it past 3000rpm at WOT just immediately stutters and flashes code 34
SO FAR I HAVE
sealed all boost leaks
regapped plugs from .31-.28
checked afm it just flashed the correct ohm for a second
MY QUESTIONS ARE
the turbo is shot it has a ton of play and i found oil in the intercooler piping bad seal maybe ?
the intercooler had 3 holes in it so i just bypassed it for the time being.
would the bad turbo or no intercooler cause a code 34 or boost stutter
also when i regapped the plugs and removed the intercooler the problem got way worse the stutter was much harsher
THANKS FOR ALL THE HELP
SO FAR I HAVE
MY QUESTIONS ARE
