i did a search and found some good info from this thread http://www.supramania.com/forums/showthread.php?t=64817&highlight=code+31
so after getting my car running again. it idled fine but when i push the throttle it dies which i know happens.
and i know the 31&24 codes are related to the afm
but what i'm having problems with at first it idled fine then died or i push the throttle and it died but now it won't even start or if it does it bubbles then dies straight away or sounds like its misfiring. i did have a fiddle with the cables around the afm and cps is it safe to say i jolted something in the cps causing a misfire?
if it makes any difference i just re torqued my head down to 108nm.
*update*
also getting a code 51 now which could be the throttle position sensor i think?
cheers for any help.
*update*
