Code 24???
YoNkErS87t
streetside mechanic
In the Garage
What could cause this code to be thrown. I didn't even know the car had a intake temp. sensor or what ever it is.
Any Idea guys???
Bishop92t
773
USA
www.ma70.com
According to the TSRM removing the HAC will result in it's own code, a 35. Either way, try plugging the HAC back in, resetting the ECU, and see if the code goes away.
Squid699
Manic Mechanic
Chesapeake, VA
code 24=bad afm, afm circuit wiring or ecu. Check the afm sensor with a multimeter or swap it out for a different one and work your way up. Most times its just the afm sensor.
