I have an intermittent code 22...the CEL will come on, then go off, then come on, etc in non-uniform intervals
I looked in the TSRM and the drawing is hard to interpret which sensor is the "Water Temp Sensor"
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=113
So I started to search and I found this picture, in this thread
http://jdub.supramania.com/Mechanical/Thermo Housing.jpg
http://www.supramania.com/forums/sh...-7MGTE-Intro&p=1398141&viewfull=1#post1398141
It appears the OP rewired the "Radiator Cooling Fan Sensor Switch" and their Code 22 went away...but I would expect the "ECU Coolant Sensor" to be the "Water Temp Sensor"
So...does anyone know which sensor is the cause of the Code 22?
Any and all input is appreciated!
