after i put my engine last week i started getting code 21, i looked it up and it says o2 sensor deterioration. so figuring because my o2 sensor was old i bought a new one (denso 234-3051) and it has the correct plug but the code is still there after i tried clearing codes by pulling efi fuse and then disconnecting battery when that didnt work. when i was changing the sensor the receiving end of the plug on the harness broke so i just have the pins but i do not think that would cause the code would it?
also, my air fuel ratio gauge works
