Hey all! So i wired in the timing control on my 91 Supra....here is the diagram that I used...http://s230.photobucket.com/albums/...on=view¤t=supratimingcontroldiagram.jpg I turn the key and the car starts, but will not stay idling....I guess I should add that I have not messed with or done any changes to the settings on the maft-pro except for the main scale which is now at -20 due to my 680s.
The directions on the setup are not very clear to me. Also it says to use the WOT Spark and AUX tables to change timing +5 or -10.....what does that mean? I guess what I am looking for is the rpm range vs timing setting beginning at 2000 rpm. I am thinking I just need to input the values so that the ECU can get an IGF signal, I triple checked the wiring and it is exactly how the diagram displays. If someone could help me with the directions on how to setup timing control values into the spark and aux tables, i would appreciate it....
