Code 14, 24, 31, 34, 52
Jason Is Dizzy
Boost Addict
Feb 4, 2009
23
Bay Area
Hey everyone another forum on codes lolz :1zhelp:
1991 turbo supra
rebuilt motor 20k maybe on it
dragger exhaust
hks DP
profec B
K&N intake
Spearco IC
hks bov
t04e .60 turbo
so code 14 has been there before the rebuild and ever since its weird. I swaped the ignighter and nothing.
code 24 intake temp sen ???
31 AFM signal ???
34 Turbo Press sensor ???
52 knock gunna rewire it and see what comes up
any help where to look for 14 24 34? that would rock thanks
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
I am going to second forced...that's what I had to do to. I bought a used harness and then the car wouldn't star. Went from one side of the ecu to the found a lot of wires miss pinned....2 days later she runs like a champ and I've not had an issue since
Jason Is Dizzy
Boost Addict
Feb 4, 2009
23
Bay Area
has anyone used the ones from suprasport?
i might pick one up or find a buddy with one
ForcedTorque
Join the 92 Owners Group
6,099
I believe it was 935 that will re-work yours if you sent it in. For $150 he will replace all wiring with the proper color wiring, and replace any needed connectors, and re-loom it. Check 935 Motorsports section in the vendor section. Detail may be slightly different, but that's how I remember it.
ForcedTorque
6,099
I honestly want to help, but I don't want you to waste your money. You might want to try some of the tests in the TSRM before buying a harness. A new one did fix a lot of my problems, but our problems weren't exact. I didn't ever have 52. That one code would almost be enough for me to chase down a harness on it's own, with as many headaches as I have seen it cause. I was lucky enough to find a harness that had been bought new about a year before. The 935 repair is very interesting to me. I can't personally recommend 935 though, as I have never had any dealings with them.
Jason Is Dizzy
Boost Addict
Feb 4, 2009
23
Bay Area
yeah im gunna do the basics today check the plugs the wires the ignigter ground then im gunna borrow a friends afm to see if that will get rid of the codes. and the knock im just gunna hace to rewire probably
