Well I've been battling this issue along with many others since I've "fixed" the BHG... Its been on-going...almost 2 years now arrr...
Anyhow,
I am getting code 12 with HARD COLD starts, takes 2 cranks to get it going and then it stumbles a bit then all is fine. :1zhelp:
TSRM SAYS:
Diagnosis
-No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked.
Trouble Area
-Distributor, or CPS, circuit
-Distributor or CPS
-Starter signal circuit
-ECU
- I've done the resistance check on the CPS and all checks out
- I even checked the connectors for good contacts on cps etc and have rewired/soldered them.
- I've pretty much ruled out the CSI and its timer switch with restance testing
- I've rechecked the timming and its all good at 10 TDC with the diagnostic box jumped.
- I have new ignition wires and spark plugs.
What else should I be checking? Some people say this code deals with the ignitor, but I see no mention of it in the problem area list unless it falls under the "Start signal circuit category"
-Thanks
Anyhow,
TSRM SAYS:
Diagnosis
Trouble Area
-Distributor or CPS
-ECU
-Thanks
