Code 11
supraman508
496
maryland
This is the situation, i start Christine when she is cold and no problems,but after she is at operating temp i'll start her again from shoping and she won't start.I'll turn the key and it's like no gas is getting to the engine.I'm thing that the problem could either be my distributor or the fuel pump is going.It takes me several times to start her after running her for like 30min.Has anybody have this problem.I have'nt done any research yet due to i would like to hear if anybody has a simular experience:aigo:
supraman508
496
maryland
GrimJack;1367788 said:
Code 11 is interruption in power to the ECU. Check your grounds at the back / bottom of the intake manifold, and check for power at the ECU connector.
Thanks GrimJack,i'll do that plus i had to cut the black neg.ground to the battery do to it was to long and the hood would allways push down on it when it was closed.i had to wiggle it so i could start the soup due to it was creating a short.Thank again
