clutch softline delete?
taka21
363
washington dc
just wondering if anyone has run hard line all the way from their clutch master to the slave (deleting the softline)
and were there any issues with it
thanks
lintlars
ROOTS RADICALS
Ft.St.John BC
Get a braided line if your bent on replacing in order to re and re the trans or clutch the line has to have some movement rather than having to bleed the clutch everytime. I personally have had no issues with the stock rubber hose.
rakkasan
Currahee!!
Fort Campbell, KY
thanks
I do, no issues at all. In fact, I think that Aaron sells it now, so check out driftmotion.com. I wonder where he got the idea :sarcasm:
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
i think it made my aftermarket clutch "softer"
cause it felt just like the stock one that was in their before i pulled the motor.
and im running the southbend dxd, which is just a modified aisin pressure plate, but still, it feels really nice and easy, but you still have that "direct" feel with the clutch.
The full length braided line isn't necessary, it was mainly made for when you swap from auto to manual and didn't have the hardlines...
taka21
363
washington dc
the whole reason for the post is that im having some issues with my clutch system
i changed out the master cylinder and havent done the slave yet and the soft line looks really beat
the issue is that after bleeding the system multiple times the clutch pedal still doesnt come all the way back up and the engagement point is really close to the floor and its really annoying cause no matter what i do it just wont firm up like i think it should
any ideas?
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
taka - adjust the master cylinder rod that comes into the car.
Or just adjust everything according to the TSRM.
oh, and i got my line for hella cheap, so i said why not!
Don't force bleed the clutch system, it's not needed.
Just gravity bleed it and make sure the clutch pedal freeplay is setup right...
rakkasan
Currahee!!
Fort Campbell, KY
One other advantage to the DM line: When removing the motor/transmission, disconnect the slave cylinder from the bell housing, pull it up to the master cylinder and zip tie it out of the way. No need to bleed it when putting it back in :)
shaeff
Kurt is FTMFW x2!!!!
11
Around
You can do that stock, just not all the way up to the MC.
Well, I did that the first time I pulled my motor, anyway. But I zip tied it to the fuel line area if I remember correctly. It was plenty out of the way.
rakkasan
Currahee!!
Fort Campbell, KY
My original one must have been bent or misrouted(?) when I did the R154 swap, because it didn't look possible.
