Clutch Setup For w-58
Fuzz420
Are U Here 2 take My Baby
Im currently clutch shopping and im looking for a clutch thats capable of holding around 450ft/lbs of tq.This will be going on my dd so i want something that will slip. I was looking at the spec stage 4 clutch on horsepowefreaks but it really didnt have a rating for it.Theres not many selections for the w-58, so if you have a suggestion for a clutch setup thats not too harsh and will hold 450ftlbs/tq
Shoot it by me. Thanks
CassMori
Boost Addict
I've got the Spec stage 3, also from Horsepowerfreaks - don't remember right off the torque rating though. It's a 6-puck, and takes some getting used to - but I've had it in my DD for over 41k, and I've been very pleased with it.
Fuzz420
BorHor said:
iirc the w58 cant hold much more then 300 ftlb/tq.
Theres no definete number so i will let you know ;)
Thanks, i havent really been looking at the puck clutches, ive heard there harder engagement is harder on the tranny, and they are less than desirable for dd's.How does yours do in traffic, can you take off gracefully or is it rough.
CassMori
Boost Addict
Pulling out is fine, the hard part is doing it without the clutch squealing :) - usually between 1700-2000 rpms works well for me. I can pull out as low as ~1100 rpms, with the clutch complaining. But, you may want to look at the stage 3+, it's a full-face disc, and I've heard it will hold a little more power than the 6-puck stage 3, without having a heavier pedal.
Fuzz420
Thanks for the feedback,really helps alot.I did look at the stage 3+ looks pretty good rated @ 465fttq:naughty:
shaeff
Kurt is FTMFW x2!!!!
11
Around
i'm not in the viscinity of 400+ yet, but i'm pushing a bit over 300rwhp through my w58 with a clutchmasters stage 3 and a fidanza lightweight flywheel. it's great. it holds the power, full face carbon/kevlar disc, the pedal feels like stock.
i love it. however, i'm not sure how much power it's going to hold... i guess i'll find out!
-shaeff
williamb82
909
4
Tampa, Fl.
ive got a centerforce dual friction pressure plate with a 6 puck metalic sprung hub disc. it has held up to 18psi on my 57 trim ct26 and 275/50/15 nitto's with a clutch drop at 6k on a drag strip. id say itll hold more then your w58. soon ill put this in my n/a mkii and swap over to an rps 3200lb pp and custom 4 puck metalic sprung hub when i put the t56 in.
