Clutch Question
With a 2jz and a R154 tranny, what kind of clutch and flywheel would you guys use. Would it be possible to use a 2jzgte clutch and flywheel, because i cant seem to find any 7m clutches that will hold around 500 crank with room for improvement and streetability (if that makes sense).
89supturbo
186
Delmar, NY
you need an R154, a 1jz bellhousing and flywheel both of which are available through driftmotion and then everything else is 7m parts, as fas as a clutch that will hhold over 500hp for a 7m Horsepowerfreaks makes a bronze clutch good for 600hp and 2 feramic clutches good for something like 600-800hp, if you decide to get one keep in mind a number of people have had issues with those clutches welding to aftermarket lightweight flywheels
tissimo
Stock is boring :(
Melbourne, FL
Im using a spec stg 3+ rated at 620 ftlbs.. it should hold.. i hope
after I go single I'll probably go with a rps c/c
