Clutch Play
YUNGPIE
17
BAKERSFIELD CALI
sup guys i got a ? my clutch just startd doing this when i push 3/4s of the way it dont grab until that last quarter i bled it and it still does the same thing is my cylinder bad ?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
If either cylinder was bad, it would leak. If it leaks, there wouldn't be as much fluid in the reservoir. Sounds like you may have a worn clutch, instead. Or something that produces the same symptoms.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
Two things come to mind. One, there is a adjustment pin for the clutch pedal, it may have come out of proper placement. Second, worn clutch, prepare yourself if this is the case. Just replaced mine last weekend, not fun. Though I must say I recommend an ACT setup, I'm using their Xtreme w/6 puck sprung, so far, superior to the RPS 3200 w/6puck sprung setup.
YUNGPIE
17
BAKERSFIELD CALI
dam when i look under and have someone push the pedal the plate comes apart and it still grabs the same i had it apart awhile back for the rebuild and it lookd good to me but maybe hopefully not
