Clutch Master Cylinder Rebuild Kits
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
where do you get a new one for 28 bucks???
the cheapest i've found is 57 bucks and go as high as 75 bucks
staticpat
Supra Chair!
Birmingham, AL
Rebuild kit works great for the ~$8. No reason to replace the whole thing if the only problem is old seals/rubber. Then again I always feel smarter when I fix a problem instead of replacing it.
The Reaper
Jan 10, 2006
1,909
Florida
yea i know i'd like to have a new one and i will be buying a new one now but i guess i'll just bleed this one every morning until i get the new one in
The Reaper
Jan 10, 2006
1,909
Florida
i can get a replacement here i just wanted a cheaper alternative until i can buy a new one
this damn 1J is killing me with all this shit
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
i used the $8 rebuild kit 4 years ago and its still going strong. I needed it asap and was broke at the time. do what your budget allows
bwest
May 18, 2005
502
HippieTown, CA
took me an hour - it would take 5 min less to swap in a new one. I spent more time dicking with the the pedal clevis and bleeding than anything else - which you would do if you were swapping it anyway.
YMMV though
Adjuster
OEM is Asin.
Same with your transmission, and many other parts on the car. (Asin makes the parts, and Toyota assembles them into cars.)
You guys realize that about 80% of most cars are "made" by companies other than the car builder?
I have "mopar" shift forks in my Asin R154 trans... (Same trans used in Jeeps, GM pickups and lately the Solstice...)
I'm sure the clutch MC is also used in many other brands of vehicle too, not just Toyota. :)
