Alright so heres the story.
Drove my car 2 hours 2 calgary so my rev limiter could be raised from 3800 rpm to 7200. Everything was good and i made it home no issues.
I slowly started reving the car further and further and runing more and more boost. (i'm running HKS V-pro so it slowly self learns as u drive) the car was running great and makin a plenty of power.
after a second gear pull with one of my friends i went to push the clutch in and the pedal was lower than it should have been. When i engaged the clutch my car stalled.
Now every time i slightly engage my clutch i can hear and feel a ratle/grind and my cars vacum drops from -10 to -5 and the car generaly stalls.
the car drives 100% and the clutch fully engages and disengages, just grinds when u press the pedal down 1-2 inches. There are no fluids leaking and i checked the resevoir is full.
*i have a jdm 1jz supra with an rps max clutch and jun lightweight flywheel* less than 3000 miles on it with a 3800 rpm rev limiter so it aint burnt out
Thanks for the help!
