clutch is not engaging
MK3Racer89
146
:1zhelp: i dont know i just put everything back on my car and started her up everything seemed normal then i tried to put her in gear then i found out that it would not go in gear at all :nono: i dont know what the problem is it felt like i needed to bleed the brakes so i did like 6 times but still not working :3d_frown:. soooooo iam stumped whent he car is off it goes into gear just fine, i checked for leaks and everything but nothing. i dont know was is going on but i was wondering if anyone knows? :1zhelp: but i think tues or wen i am going to take it to toyota (i live close by it :icon_bigg ). i was going to have my a/c refilled and my heater fixed so i guess i since it is going down there anyway i will get all i can done with it. i was so happy to finally have my car done but then it cam crashing down :cry: i want to drive so bad but yeah if anyone has any info on it much thanks
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
did you reassemble it yourslef. like the clutch pressure plate and everything else? Maybe you put the enti rethrow out assembly outside the pressure plate towards the transmission :1zhelp:. someone else did that and they couldn't engage. i don't remember who tho.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
yeah the toyo throw out bearing is very different setup than what ive seen on other cars, it pulls instead of pushes... sorta backwards.. and after i took it apart i almost installed it incorrectly.. i was definately nervouse when i got it back together... it works good. did you bleed the air out of the clutch slave cylinder?
shaeff
Kurt is FTMFW x2!!!!
11
Around
only on turbo cars, and tranny swapped n/a's which use the r-154 transmission. the w58 (nonturbo) tranny is a push type.
-shaeff
Spiv
hooligan
Orlando, Fl
when you try to put it in gear with the car running, what kind of resistance is it? Like does it grind? Also, have you tried putting it in gear, push the clutch down, and start the car (making sure there's nothingin front of you, of course). Not engaging, and not disengaging could be two very different problems.
MK3Racer89
146
sorry for being so vague i was in a hurry but i changed the pp and clutch. i took the whole clutch off the car, i got my fly wheel reserfaced and then i put the tranny back on with the pp and clutch disk on and bolted it up while the tranny was on the car. i checked everything and bolts etc. all were tighten down and everythign looked to be where it was supposed to be. but ok when it is running i push the clutch in and it seems like it needs to be bleeded, it seems like it almost go into gear but it wont and there is no grinding at all, it just wont go in. i dont hear anything werid noises when it is running. but when the car is not on it sounds normal and the pp and clutch disk is a ACT clutch kit.
aye mate
Hiatus over.
Maryland
That was me. DOH! Yea I put the TO bearing in backwards so that the snap rings faced the engine. Toasted my Spec st.2 disc and resurfaced flywheel in 8k miles. I'm surprised it lasted that long. That included 5 runs at the track.
Mr.PFloyd
Jun 22, 2005
3,964
hahah jokes. glad to see you learned :D
Boosthpy
133
Idaho Falls
The car i am going to buy is having the same problem. The lady told me that the shift fork and throwout bearing needs replaced. Hopefully it is something stupid like the fluid is low.
gixxer750
2jzget comingsoon!
Mississippi
how did you manage to get it to work like that cryoslash? I did that, and the pressure plate wouldn't bolt up to the flywheel due to the clutch hub hitting the throw out bearing.
Boosthpy
133
Idaho Falls
I don't mean to jack your thread man but i am just tryin to figure out the problem with my car as well.
I just checked the car and it had no fluid. We put some in and tried pumping it and the level didn't go down or nothing. Any suggestions? If they did put the throwout bearing in wrong would it still engage and disengage? Any help would be awesome.
shaeff
11
Around
you have to bleed the slave cylander in order to purge the air from the lines. :)
-shaeff
