I'm at work and I don't have a clock here to check this. I need to know which circuit the following pins on the back of the clock connect to (they're labeled on the PCB the wiring harness connects to inside the clock):
G - I believe this is the Ground (pin 4 in the TEWD)
L - Perhaps the Taillamp circuit? (pin 2 in the TEWD)
D - Perhaps the 15A Cig circuit? (pin 4 in the TEWD)
C - I suspect this one is on the Dome circuit. (pin 3 in the TEWD)
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=128
If anyone can help it would be great, if not I guess I'll have to wait until later tonight.
