I was wondering if you guys knew a easy solution *solution as in liquid mixture...or not* so clean in between the crevices of the sawblades and get the dirt out
you can try simple green when the wheels are NOT hot spray them on it and use a wheel brush and clean them. Or some acid wheel cleaner. dont leave it sitting on it long. Mix the simple green with a rag and stick your hand in there to clean it
