Choice of Pistons ROSS or JE
jdub
Feb 10, 2006
10,730
Valley of the Sun
It's hard to say, but I'll bet he bored it without the main bearing caps torqued down to spec...the cylinder walls on a 7M are on the thin side anyway and can be distorted when you start torquing on it. Especially when you go to the larger oversize bore. Make sure he uses a torque plate and the timing belt tensioning pulley is torqued down to spec too.
supraguy31
626
Pembroke, NC
So you are saying that when I go to get this block bored out to have the front cover on it already. Im going to have it Decked just to make sure and I know you need the cover when you have it decked but I wasnt for sure if it needed to be on when you have the Cylinders bored and Honed
spoolint78
Representing T.O
T.O
i never had a problem with them.
Unrefined? Not sure, but they work.
So why mess with something that works?
just my 2 cents
bigaaron;902655 said:
Ross pistons are old school technology, unrefined, heavy ass pistons that don't take abuse well at all. I will never use or sell another set of Ross pistons again.
How do you figure that?
(In my experience they hold up really well to abuse due to their mass)
supraguy31
626
Pembroke, NC
Ok, I knew that there was someone that would have a not so Positive comment about them which is fine but Please elaborate on why they are so bad. I see that you have Probe Pistons on your Site so what makes those any better than the ROSS pistons or is there a Piston that you recommend.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I have two sets of pistons with the crowns broken in the same place. Neither one was run super lean. I have already posted pics in the past showing how the Ross is an old 2 valve per cylinder casting that they use for the 7m. The Ross pins that come with the set are too weak for the weight of the piston also. A piston that heavy can cause standard pins to flex. I would use CP or JE or Probe or anything but Ross. I have also been warned by several machine shops that Ross makes a habbit of screwing up custom orders. This is not only my opinion, but also several other people I know who have been in the industry for a lot longer then myself. I try not to make claims that are not backed up by personal experience and research.
bigaaron;902792 said:
I have two sets of pistons with the crowns broken in the same place. Neither one was run super lean. I have already posted pics in the past showing how the Ross is an old 2 valve per cylinder casting that they use for the 7m. The Ross pins that come with the set are too weak for the weight of the piston also. A piston that heavy can cause standard pins to flex. I would use CP or JE or Probe or anything but Ross. I have also been warned by several machine shops that Ross makes a habbit of screwing up custom orders. This is not only my opinion, but also several other people I know who have been in the industry for a lot longer then myself. I would never make claims that are not backed up by personal experience and research.
Got pics of the failed pistons?
jonny87turbo
203
ohio
I will be rebuilding my engine sometime ive never heard of probe pistons before till a couple months ago. Would those pistons be a good buy?
Or should i just spend the extra $350 on the JE.
jdub
Feb 10, 2006
10,730
Valley of the Sun
:withstupi
Haven't seen a Ross piston fail, unless it was due to the installer or it was run lean and melted the top.
Have a look at CP pistons...Suprarich stocks them. JE's would be my 2nd choice.
MRSUPRA
838
Maryland
My Arias pistons only cost about $550. The shop that built my 7M which deals with all kinds of forged pistons recomended them because of there tight tolerances. (Maybe they have a special deal with Aria, who knows?).
Ross pistons are heavy and I have heard of them having piston slap when cold.
Doward
4,245
Alachua, FL
If you can spring for them, the Arias are super nice (AND CONTOURED TO THE HEAD)
If not, the Probe pistons were 90% of the Arias @ 1/2 the cost, lol
*edit* $550 for Arias? That's a steal. When I was looking into a set of pistons before the Probe GB, I was quoted $735 for a set.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
Ross - 357 Grams
Arias - 312 Grams
According to 935motorsports....
And there the only vendor site i could find that listed piston weights... weird...
Probe - 300 Grams AND there on sale for $395 at Driftmotion! DM FTW!!!!
My point is if your going solely off of weight... the probe are the "best"...
92nsx
2,957
Clearwater, MN
I have used Ross in the past (2001) on one of my 7m builds. Dont know if was the pistons, rings, or the install, But i had a slight tick at first start up. Other then that, they were great, held up to boost i was running at the time, (15-17 psi). How ever this time around i am going with JE 40 over pistons, just because i got a great deal on them, and i wanted to try them out. :)
