Chevy SB/BB valve springs.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Well, while I know that the lift on SBC/BBC cams is (typically) greater, from what I recall, 5000 RPM was a big INCREASE in redline on those, so I'm not sure about the suitability of the springs for carst aht are intended to run at 6500+ RPM. I remember a lot of guys with the V8s having valve float issues at 5500 RPM with upgraded valves and rockers.
That's not to say that it couldn't be done. I knew a couple of guys who had 7500 RPM monsters, too.
Doward
4,245
Alachua, FL
Valve float is due to valvetrain weight vs spring used.
The BBC inners are stronger than our springs stock, so they are great!
bfr1992t
The quiet one
Oct 29, 2005
272
Ohio
Don't forget about boost pressure assisting with float on the intake valves. ;-)
I've run the 975 springs for 5+ yrs now. 1.5mm over valves, 25+psi, 7200 rpm. I had my stock 92T springs tested at 65kmi and they were weak.
