Check out these pistons! PURE SEX!! PICS!!
suprarich
Guest
Nov 9, 2005
2,187
ohio
Yes these are 7mgte pistons. Pics do not do anything for these.
Next to a stocker!
Forced oil pins
Lots of gas porting
suprarich
Guest
Nov 9, 2005
2,187
ohio
No, you are correct on that IJ. These are not a true gas porting. They only have the crank case on the oil ring.
Rich: I used gas ported pistons many years ago in a street motor......
Lasts about 5000 km then they block with carbon :(
Those are the Oil Scraper returns and perform a vital service!
(do they have intersecting holes drilled to the pin for oiling?)
suprarich
Guest
Nov 9, 2005
2,187
ohio
Yes they do.
I never use true gas porting on anything other than alcohol drag race only pistons for that very reason. Gas motor will plug the porting solid with carbon in no time. Most of my experience is with nitro, never use gas porting for nitro because the last thing we want in the world is nitro in the ring lands.
Teflon buttons on the other hand are gods gift to drag racing nitro.
These pistons are 10.5:1 comp, 305 grams with a .200 wall thickness pin.
.063 thick wire locks and a 1.299 comp height. Dome height is zero with a dish depth of -.035. Intake relief is -.23, exhaust is -.200
I had all three ring grooves custom made also.
.04/.048/.111 on the ring grooves.
2.998/2.974/2.978 on the ring groove diameters.
You will also see in the pics that I had the land between the top two grooves cut. These pistons I had custom made for a 1200hp alcohol 7m.
suprarich
Guest
Nov 9, 2005
2,187
ohio
I am sorry to say that these are not for me. I only had these designed for someone. These pistons will be shipped out via fedex in the morning to a very close friend and customer of mine who lets also say is getting a billet aluminum crank girdle, billet steel main caps, a teflon crank scraper, and is also in the midst of talking to me about a 5160 billet steel crank. if i get some vids of the thing from him once its done, I will post them for sure. Nothing like doing things the best you can the first time around.
