Cheap formula that works?
ex3cutiv3
Canada
Hey guys I want to push around 350 rwhp and just want to know af a good frmula for doing so. I have a factory 1990 with the 7mgte (sold last car).
So is there a good easy way to make this power?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Install full 3" or greater turbo back exhaust, full 2.5" hardpipes with spearco replical IC, Manual Boost Controller, 87 octane gas, Fuel Cut Defenser, set boost to 20 psi, and her rip! ;)
Sawbladz
1,727
Oshawa, ON, CA
So you bought a Supra and want to make power? Where in the world did you get an idea like that:biglaugh:
Before you do any power mods, be sure to poke around here to learn about the weak points of your car. Make sure you have a good MHG and properly functioning car before you mod it. If not, your asking for trouble.
OneJoeZee
Retired Post Whore
aboard the Argama
The cheapest/easiest way to make power? An opened up exhaust and some nitrous.
You didn't say anything about how long the motor should last, though.
TTime24
56
Huntington Beach
on 87 octane????? :squint:
Supracentral
12
themadhatter
760
Vegas
opened up the exhaust and some nitrous is going to b the cheapist way. The bottom end should hold 150 wet shot fine as long as it doesn't lean out
Supracentral
12
When this guy is back here a month from now, with a blown motor, you three can pay for it, and while he's bitching about how much the 7M sucks, as punishment I'm locking you all in a room with Nick_M and JoelW. while they argue about global warming...
MDCmotorsports
Indy 500
www.MDCmotorsports.com
You are a cruel cruel person.
To answer the question - use the search button.
To answer the question because you are lazy - 3" down pipe, 3" exhaust, manual boost controller to 12psi, 93+ gas, aftermarket air filter, some porting on your exhaust manifold and stock elbow.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
:evil2: That question was begging for an anwer like that ;). I think it was kinda obvious about the sarcasm. Your method works good too though, for a time... Still don't think he's going to get 350 HP cheap and have it last...
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
Here's your list.
ct-26 57 trim upgrade
550s
lexus afm
afc
intercooler
full exhuast
filter
bosche bov
boost controler
clutch
new mk4 fuel pump
That will do 320 to the wheels for a very long time. You may not even need the afc. Run it stock toyota rich on the highest pump octane you can find and you'll see a very reliable 320ish to the wheels.
Dump in some race fuel and run low 20s psi for 350+ to the wheels. Again, keeping it toyota reliable. A buddy's car did this same recipe for 350ish hp, and drove it this way for many years. On the stock headgasket that we retorqued to 72lbs.
