Charcoal canister?
SkyHawk Ecks
Stockton, CA
Yeah you can, but you won't be able to pass visual without it.
You need to get a vented gas cap, and route the hose going to it down under. If you don't vent it, you'll smell fuel.
jetjock
creepy-ass cracka
9,439
Son of a bitch, someone actually spelled vacuum right. Congrats, in spite of your otherwise horrific writing you win a free get out of search jail card for this post only.
The EVAP canister can be removed and the vacuum (!) line plugged at either the throttle body, the BVSV on the radiator, or the hard line on the AFM bracket. Now, I know lots of people will tell you to vent the fuel tank but it's because they don't know it's designed to run under a positive pressure of 2-3 psi in order to prevent fuel pump cavitation. A valve inside the canister takes care of that but since no one seems to have problems (that they're aware of ) by venting the tank just go ahead and do it. And thanks for poisoning the air in Arizona...better there than here.
LOL...yep we need a list of most common misspelled words ::dunce::
Joe - ADEQ will nail you on the bi-annual inspection. Also you won't pass the sniffer test without an EGR (if you're thinking about removing it)...just leave it installed. Replacing the stock downpipe (and associated CAT on the stock DP) is not a problem.
If you do remove the canister, you'll have to put it back on for the inspection...suggest you keep all the parts ;)
Caplax40
Grand Tourer
Feb 12, 2006
202
Boise, ID
I actually passed visual without a charcoal canister on my car. However, seeing as how there was no performance gain and the fact that I could smell gas fumes hovering around in my engine bay, made me promptly put it back on.
racerjoe2004
13
California
ok now that u guys have answered that ? on my supra im missing that sensor that is plugged in the pipe that goes from the head to the radiator and i have seen that other supras have that and thats where they have there charcoal canister hook up to the vacuum. can i just get a vacuum hose that goes from the throttle body to the charcoal canister or do i need that sensor
Are you talking about the "sensor" marked BVSV in this pic?
The line routing goes like this:
Small fitting on top/forward of TB to hard pipe that's in front of the 3000 pipe to the bottom nipple on the BVSV...top nipple runs to the canister fitting marked "purge" on the canister.
racerjoe2004
13
California
yeah whats that sensor for do i need it to connect the canister or do i need it at all
Buy a small JDM Plastic CC and hide it away under a fender plastic inner and don't make your car into a rolling time bomb.....
There is NO PERFORMANCE benefit removing it milage will suffer and it's fucking stupid..
hellraiser456
130
canada
i agree unless you really really need the space or are building a track day car...i wouldn't bother. no point...does more bad than good.
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
racerjoe2004 said:
can u remove the charcoal canister and if so what do u do wit
the vacuum lines
Like the boys said. "Leave it". Be creative, make it pretty.:wiggle:
