Catch can size?
Doward
4,245
Alachua, FL
I think the 15mm has a 15mm hose barb, and the 9mm has a 9mm. Since the stock size tubing off the PVC hookups are 3/8", I think the 9mm would be the one you'd want :)
Fitting size depends on the motor's condition and amount of blowby.
My stock motor used to breathe pretty heaving on the Dyno and used to blow the dipstick out so a quick fix was bigger hoses from the Cam covers to the CC and then to the Vacc source.
Larry_A
You don't matter
Apr 7, 2005
102
SoCAL
high psi 1jz said:
Oh so there's no difference in the size of the actual catch can?
No, they are the same.
Note: Greddy offers two sizes of cans, one medium & also a very large model that wouldn't fit in most engine bays. The problem with both cans is that they are not baffled in any way, so the input has nearly a direct shot to the output that does not allow full efficacy of the vapor condensation effort to be realized.
I bought the very large Greddy can then loped the bottom off, welded a P-III Slot-One alum heat sink inside the can between the in/out. This created a near twin chamber- a flow-disturbing finned barrier with large surface area maximizing condensation & fluid collection in the can instead of the intake. The can was shortened to just shy of heat sink height, & it's new demure size facilitated install on the cold side of the bay.
