Car won't start now...
gotboost2614
13
twin cities
had the car stored over the winter and never started it so battery dead.. went out to buy a new battery from autozone and somehow the guy there gave me the wrong battery.. he gave me a battery for the na model.. was told terminals were different for turbo n na model.. correct me if i am wrong.. turbo models, the positive is on the left n the negative on the right.. n na model, the other way around.. not thinking twice, install battery n SPARKS.. checked all fuses n only one blown 7.5 fuse inside car.. replace the fuse n went back to autozone n bought the right battery.. install battery, turn key to on position n the only things that lights up r my airflow, boost, n oil guages, and headlights.. try to start car n nothing.. usually some lights come on inside the guage cluster, but nothing.. COULD THAT HAVE TRIGGER SOMETHING ELSE? ECU? DON'T KNOW MUCH ABOUT SUPRA YET SO ANY SUGGESTION IS MUCH APPRECIATE.. MY CAR IS A 90 SUPRA TURBO MODEL WITH THE 7MGTE.. THANKS!
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
double check fuses
---------- Post added at 09:07 PM ---------- Previous post was at 09:06 PM ----------
also.. when you open the door.. is there any lights? light the light on the dash that shows the door open?
You prolly blew another fuse.
Batteries are the same and the posts are on the same side. The ground is always closer to the body than the pos, meaning the pos side is always facing the engine.
The batteries are in the same spot n/a or not.
The guy at auto zone was a moron.
Even if it was a wrong battery you should always look at the battery for the markings that say + or -.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,280
69
Atlanta
Kevin;1529399 said:
check the fusable link (if you have one)
What he said. Check the 'big' fuses in the engine compartment, including the fusible link- the black looped-looking wire. Make sure it's not melted, or crispy.
gotboost2614
13
twin cities
thanks guys for the input.. been working long hours now days n haven't had time to go come in here.. will check all the fuses again 2morrow and kevin, no lights are on inside the dash..
