Basics: 1990 turbo, a/t
Mods: SSQV, wastegate shimmed to around 8psi
Symptoms: car hesitates and what not off idle. Will not idle on it's own. Once past around 2500rpm's car revs very freely. Running rich. No vacuum.
Things I've tried: Coil Pack, Plug wires, plugs, cam timing, ignition timing, vac hoses, IC piping. Just finished an OEM head gasket job with ARP's and moly to 82lb ft. Also replaced intake manifold gasket with brand new felpro
CODES: 51 and 52
Anyone have any ideas? I know it says the TPS is the faultor, but I checked it according to the TSRM and found everything to be within acceptable limits.
Thanks for reading guys!
Brandon
CODES: 51 and 52
Brandon
