Car sounds like its not getting enough something
Status
Not open for further replies.
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
I have a 1987 supra. I declare it as a piece of shyt. But its mine... Anyway my car started to studder like it wasn't getting enough fuel. I would spray some throttle body cleaner through and acces. outlet in my ic pipe. and it would clear up. Then it would be fine until I gave it gas. When I held it at any rpm it would clear up. It did that for a while. But now no matter what I do the car seems to sound the same. I cleaned the injectors. installed a aeromotive fpr. Changed the exhaust manifold gasket. I had a very bad leak. finished that and its still the same. I had the car running and i took each wire off one at a time to see if its getting spark. I know its kinda stupid. every cylinder was getting spark but it wasn't all even. ????. I have no clue anymore. I have some mods done to the car also. But I never had any problem with them. the motor has about 12000 miles on it. I just need some helpful advice. i'm lost. all thoughts are welcome
shaeff
Kurt is FTMFW x2!!!!
11
Around
Thread moved.
What is the last thing you did to the car before you started having the problem? Check your diagnostic trouble codes. Use the link in my signature.
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
Yeah I'm there almost every day. Its alot easier than the book. I like to do turbo systems on supras and any other thing to them on my spare time. Thanks I'll give it another look.
Status
