Can't separate torque converter from flywheel
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
Ran into somewhat of a problem after removing the engine and transmission from one of my Supras.
After loosening and removing 5 of the 6 bolts that keep the converter and flywheel together, one of them just wouldn't budge and we ended up stripping the sides, even with a 12 point closed wrench. Any suggestions? It's just that one damn bolt holding the converter on there.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
cut the head off with a dremel, should come out of the converter easy because there shouldn't be much holding it in. worst case you need another converter or to drill and tap it.
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
I won't be reusing the torque converter as I'm putting an R154 onto the engine. Will a dremel fit in that tight of a spot? There's barely enough room for the closed wrench and my finger beside it. For all I care, that torque converter is going into the garbage.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
might fit give it a whirl.
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
Is the transmission still attached? If so unbolt the bellhousing and the torque converter will just slide out of the tranny and then use some bad ass vice grips.
Hammer and a blunt cold chisel
Figure out which way you need to hit it to undo the bolt and give it a few whacks on an angle it should shock loose.
