Can you use lexus afm sensor on stock housing?
shiftysupra
180
Tucson, AZ
yes, when people talk about the lexus afm upgrade they mean using the housing from the lexus and swapping the electronics from the 7m afm... since it is bigger you get more airflow.
shaeff
Kurt is FTMFW x2!!!!
11
Around
You misunderstood the question. :) He was asking if he could use the Lexus electronics on the stock housing. The answer to that, as posted already, is yes. :)
shiftysupra
180
Tucson, AZ
shaeff;1199096 said:
You misunderstood the question. He was asking if he could use the Lexus electronics on the stock housing. The answer to that, as posted already, is yes.
Yes I know, I should have made it more clear that just giving advise towards the "upgrade" were it wasn't needed. :sarcasm:
shaeff
11
Around
What are you trying to do? If it's raise fuel cut, you'll need some 550cc injectors, the Lexus AFM housing, fuel pump, drill the jtube, etc...
Read this:
http://rob.carlile.home.mchsi.com/lexus/lexus1.htm
If that's what you're trying to do, then you really need to be more clear when asking questions, because that's NOT what you asked. ;)
Supracentral
10
mk3tattoos;1199167 said:
SO im alittle cunfuse, so i need the lexus housing NOT the sensor? thanks guys
Combination|Result
Lexus AFM Housing + 550 cc/min injectors + stock electronics|higher fuel cut
Lexus AFM Housing + 550 cc/min injectors + Lexus electronics|higher fuel cut
Lexus AFM Housing + stock injectors + stock electronics|dangerous
Lexus AFM Housing + stock injectors + Lexus electronics|dangerous
Stock AFM Housing + stock electronics|stock
Stock AFM Housing + Lexus electronics|stock
mk3tattoos
1,104
Bremerton, Wa
Read this:
I have everything i need. But my friend who is a machanic, (and owns Brightside imports) was under the impression you only needed the electronics off the afm. But i knew something was wrong when i keep hitting fuel cut. I was cunfussed because i was getting wierd answeres, i thaught it was cut and dry.
Who
Supracentral;1199251 said:
Combination|Result
Subscribed.... One vote to "Sticky" the above table
shaeff
11
Around
This is all very common information. First, your mechanic friend is dead wrong; how do you expect to get roughly 25% more airflow without changing the housing? Second, take a minute to really read the link I provided earlier in the thread:
It's got everything you need to know, especially coupled with Mike's chart above.
mk3tattoos
1,104
Bremerton, Wa
i read it as soon as you put it up and then i saved it. I understand he is dead wrong but it happends. I"ll post some pics of the incredible builds he does. you will shit yourself!!!!!!!!! Then you can be the judge of his skills! our cars are very old and out dated, he is going to have to get more info on everything. realy we were not planning on using any afm, but money is tight in sothern california! well thanks agian for all the great info, realy help alot.
D7MSupra
Ive Infracted
Apr 6, 2008
160
Richmond, Virginia, United States
im glad this thread came up because i wasn't sure about the upgrade either and how to do it safely. i wish i would have known b/c i had the part in my hand one day at the junkyard and i could have got it for cheap probably. the carisle artical got me understanding perfectly.
