Not a pic of my engine bay, but just one I found on the net. I Have a 86.5 7mgte.
Basically have had problems where car will idle low/stall after warming up/boost and a mechanic has decided to disconnect that hose and block both ends up. So that valve (or w/e the proper term is) is blocked and that hose that would otherwise be connected (and appears to go around the back of the engine) is also blocked.
Have not tried driving it yet (but it does run fine) to see if the problem is fixed (somehow doubt it) but is having this blocked/not connected OK? Will it cause more trouble, or better yet what exactly does it do. Seems to be something vacuum related?
Cheers
Cheers
