A little history: I have a 1987 7MGTE that hasn't been driven much that last four years, which is probably most of the issue. I took it to Reno for Hot August Nights 2 years ago and it won't idle on its own. It trys to idle in the low 550-600 RPM range and tries to catch itself then dies. I have to hold my foot on the gas to keep it running. 2 years ago it obviously had new gas and new spark plugs before the trip and still had these symptoms.
I took it on a long road trip, around 90 miles last weekend and it still has the same symptoms even with fresh gas. I went ahead and changed the spark plugs to the NGK BKR7Es today and decided to remove the ISCV and see if it was gunked up. I had quite a bit of gunk and I decided to go ahead and clean it up. I soaked and scrubbed the apparatus (not the sensor) and the check valve in Dawn. The check valve doesn't have any tears etc but it doesn't seem all the way closed in a static position. See attached photos. Of course when I blow through the wagon wheel, air comes out the other side.
I am wondering if a new one is needed? It's a 40 dollar part and I don't want to order a new one to find out it looks the same. In my mind under boost, it would force the silicone seal shut and wouldn't leak and under vaccum it would flow through the iscv and check valve into the manifold. Meaning it would be ok as is.
Any ideas on whether or not a new one is needed?
For those still with me, I went ahead and tested the ISCV via the TSRM and am unable to get a lot of movement in either the open or closed direction. Hoping this is causing my idling issue. What's the best way to clean the motor? and ReLube? Can I just use electrical cleaner?
My AFPR was reading very high, and didn't change with the vac removed, so I decided to clean out my Aeromotive AFPR. I didn't see any gunk so I re assembled. I currently have vacuum coming from the stock location, and decided to switch to where I have my Zeitronix Map plumbed, it got much better. But I find I have to run almost 30psi with the vac connect to get it to run ok. At stock boost (wastegate crack pressure) AFRs are from 11.2-12.4. So that should be ok, no idea why the pressure needs to be so high though. I'd like to clean the vac lines etc but I don't know of the best way? Compressed air? Seafoam? What do you guys think?
Thanks for any help or advice! I will have more questions to come and am looking forward to returning to active status on this awesome forum!
