Can I fit 275's on MK4TT wheels?
Tura_1JZ
Supra down the block
Aug 26, 2009
114
miami
I searched and came up short, I was wondering if i can fit 275's on my mk4TT wheels without hitting the shock.
SilverSupraT
7M '78 Toyota Pickup
Oct 3, 2005
556
Eastern WA
www.geocities.com
That's the recommended width for that rim (the rears) and mildly lowered MK3's can run that combo with no problem. And you can have an extremely low ride and fit them as long as you fix them camber.
shaeff
Kurt is FTMFW x2!!!!
11
Around
As everyone stated, for the rears that's fine. Not the front's though. I wouldn't go any wider than 245's on the 8" wide front rims. Anything larger and you're not using the full potential of the tire.
Supracentral
12
The proper stagger setup for these rims with that rear width is:
275/40/17 Rear
245/45/17 Front
Reasons are that these are the perfect widths for those rim widths, and the height for these two size/profile combination is within 1/10th of an inch of each other.
