Camshaft & Oil Pump washers
Doward
4,245
Alachua, FL
The washers under the bolts to the camshafts, and the oil pump drive shaft - I need to know the thickness, and width of them.
Don't feel like waiting on Toyota, when I can just get some grade 8 washers from the hardware store ;)
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
I'll head out to the garage right now. :)
This is Camshaft.
4MM thick
30MM wide
10MM Hole
Oil Pump is on the block
4MM Thick
38MM wide.
8MM Hole
Couldn't get the other two.
I used my Vernier.
Doward
4,245
Alachua, FL
Appreciate it! I'll go 4mm on the oil pump as well ;)
so I need 2 30mm wide, and 1 38mm wide. Awesome. The oil pump shaft bolt is, iirc, 8mm just FYI for anyone that searches this ;)
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
I did a eyeball comparison on the Oil pump washer and Cam washer lined up side by side on the shaft and it is 4 MM thick.
Just incase someone searches this i edited my post.
