cams cams cams
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
yes but i am not sure there give out spacer ring if they do that be awsome
think i a going to have to call them up i guess
i kinda wana run per bought one's if i can
MRSUPRA
838
Maryland
I have the BC 264 cams. I had to return my first pair.-Car wouldn't idle at all, and of coarse Brian Crower said they were fine. The second set he sent me worked great. I'm making just under 500rwhp at 17psi with conservative timing with a little GT35R.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
you mean welded cams i sean poepel run them wiht no issue if the guy that is doing is getting them harded after words
MRSUPRA
838
Maryland
The first thing I noticed after installing the 264 cams is how the off-boost power got softer. But there is no decrease in boost response or "lag".
Topend is nice. I have my limiter set to 7200rpms and it pulls very hard all the way through. I can't imagine using these cams with the stock rev limiter.
Local company Wade Cams here in Australia, they're hard face welded so the same shit they use on the teeth on Bulldozer buckets, been running them for years now and there's 0 wear.
Back when I had them done Billets were rare and I didn't want a reduced base circle.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
what is done to your head any thing diffent?
and were does the car power fall cause i wana go to 7000 rpm atlest
