camber adjustment
rsaeini
padawan
Oct 30, 2006
85
SoCal
after doing some searches i found that the stock suspension can be adjusted.
i'm trying to find out who out there has adjusted this and what the most common settings are.
i'll be replacing my rack & pinnon soon and i'll need an alignment so i might as well set my camber as well.
thanks
ray
rsaeini
padawan
Oct 30, 2006
85
SoCal
any specific settings that you have them set it to?
for example, on my S2000 i have it set to roughly 2.5 degrees of camber. do you know what they are setting it to?
how about the toe?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Mine is just set to streeting specs. I can find the paper that shows the specs but it wouldn't be much help. What kind of set up are you looking for?
rsaeini
padawan
Oct 30, 2006
85
SoCal
just trying to see how much adjustment the car allows.
it's going to be lowered on H&R's and Koni's. just want something i can cut some corners with, not too serious...it's a street car afterall.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
this is point less thread every car sits at diffent hight witch afects camber caster toe so all you got to do is grab a bubble gauge make your self a toe in box and you set to start mucking around
