cam shafts and valves
remkye08
Learner
Oct 1, 2009
82
Round Rock, TX (Austin)
Sure timing didn't jump? Does the car feel really really weak?
no it didnt, i double checked, yeah really weak, and when i put 5th gear the car sounds like the engine is being forced, like when u put 3rd gear going at 10mph
Suprapowaz!(2);1473209 said:
Maybe your distributor hold down bolt got loose somehow and it moved. Check to see if your distributor can move freely.
no bro, i just went outside to check it and is fine
thanks guys for the help
any other suggestion?
89nasupra
Sugar, Water, Purple
Apr 8, 2008
501
Lafayette, Louisiana, United States
do a compression test. my car did the same thing and i blow the head gasket between 4 and 5 cylinder. i also had my crank pully bolt come loose and i thought it was rod knock cause it ran really bad and made alot of noise.
my .02
AJ'S 88NA
2,419
Florida
:wtf:
NYsBlueMA;1486144 said:
I had that problem check your plugs mine exploded I barely got home and they were a week old and check the throttle body there might be a slight to insignificant leak that electricity might follow
:wtf:
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
are you sure your VALVE timing is correct? Might have jumped a tooth. turn the crank to #1tdc compression and make sure the cam gear marks are strait up.
double :wtf:
Suprapowaz!(2)
2,870
San Antonio, Tx.
Ok, it's been over a month. Any updates? Did you find the problem? Did you do a compression test? Did you check to see if your cams are pointing straight up with crank at TDC? What all have you done?
jdub
Feb 10, 2006
10,730
Valley of the Sun
:wtf:
Over.
This (without a doubt) is the most worthless post I have read on SM.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
:wtf: to the fourth power.
Exploding plugs and throttle bodies leaking electricity?:umno:
:: facepalm :::nono:
AJ'S 88NA
2,419
Florida
IJ.;1486819 said:
I came close to locking this thread based solely on that one post.... :nono:
The STUPID is strong with this thread and it's attracting more and better stupid.
Yup...and you can't fix stupid.
Good for a laugh though:)
suprarich
Guest
Nov 9, 2005
2,187
ohio
Who had your dist. pulled and installed back several teeth off? Not a knock, not a BHG, thats a timing/spark issue either mech.,electrical, plugs,or TPS maybe.
