Cam Pos. Sensor, Please Help!!!!!!!
Supramk389
23
Connecticut
Does anyone know the wiring for the cam sensor? I had hardwired my old one to get rid of the plug, it was NG. The wires finally went so i installed a new cam sensor and now the car wont fire. It's only four wires. Should I just try each possible option? Or does anyone know what wires from the harness connect to the wires off the cam sensor. Sorry if it sounds confusing...Thank you for your time.
7mgte1988
7M-Runner
Sep 22, 2008
223
Orlando
They should be color coded right?? i had this problem a while back a slight bump kill the car
Supramk389
23
Connecticut
It seems there is a red and green but the other 2 are too alike...maybe white, yellow or brown. How do you know how to mount the CPS?
7mgte1988
7M-Runner
Sep 22, 2008
223
Orlando
red-green,green-red,black-white,yellow-yellow thats the way mine is
7mgte1988
7M-Runner
Sep 22, 2008
223
Orlando
Supramk389;1304367 said:
Cool, I'll try it...that slide for the mounting bolt...does it matter where it's positioned?
yea it matters its the timing. i would put it in the middle and then start the car then adjust from there
rayall01
901
Westfield, ma
This picture is of my CPS at TDC. Put your engine at TDC, and line up the CPS like in the pic.
