*Cad File Request*
Boosted: LOL thanks!
JJ: LMAO Yep real easy to crash an expensive cutter ;)!
(had a few mishaps as before I built this machine I'd never been hands on with a CNC so the learning curve was vertical)
Theraputic goes out the window if you have to make 100 of one part!
I'm sort of lucky being self taught I don't know that I can't do something so just do it! (All of my machinst friends are a bit shocked when I tell them how I've arrived at a solution)
When I did the exhaust on my car recently it was the first steel GTAW I'd done so was a bit shocked how low I had to set the current! (about 28a seemed to be a the sweet spot)
Had a play around using my A4 scanner and doing the scan in 2 halves this afternoon but it's not accurate enough for my purposes so I'll see if I can track down an A3 scanner to do it in one piece!
<fingers crossed someone turns up with a Cad file already done>
