As JetJock said, however if you run those 2 wires through firewall to lower neutral start switch on clutch pedal, you will also have your cruise.
This is assuming you were swapping a 5 speed into an auto chassis. If you simply jumper the wires the ECM thinks the car is in P or N at all times and of course cancels the cruise out.
I just completed this swap 3 weeks ago, wired as stated above, cruise works like it should ^^
