Bypassing heater core (loop or block off)?
Devin LeBlanc
1,830
Las Vegas NV.
Well I've got a question. When bypassing the heater core should I block each port off, or hook the two lines together?
I have had them blocked off for the last year and a half but in the summer time (today it was 120+ out) with the A/C on my temps start creeping up only with freeway driving.
Have done a leak down and compression check no leak down to the cooling system what so ever. Compression is all 170 at the lowest 176 at the highest (9.2:1 compression ratio) There are no exhaust gasses in the cooling system. The car does not have a BHG. Cooling system has been pressurized to 20 PSI with no leaks.
Doesn't loose any coolant or over heat with normal driving. Has a 3 row dual pass nascar radiator with a properly shrouded Tarus fan on high. Brand new water pump, new radiator hoses, tried a 190F and 180F temp thermostat with the same issue.
IBoughtASupra
4,455
Queens, NY
Loop them together. I have never blocked coolant lines off except the rear nipple for the twins on the JZ motor. Always loop as it will avoid hot spots.
The coolant will just sit there in the spot you capped off.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Devin LeBlanc;1754854 said:
Is that a spot that flows? Even when its hooked up the valve shuts it off so coolant doesn't flow to the heater core right?
Thats my understanding. With the valve closed the coolant sits regardless.... That shouldn't be cause for a rise in temps. Is the radiator brand new? Can you ditch the taurus fans and restore the higher flow stock fan?
Devin LeBlanc
1,830
Las Vegas NV.
The Tarus fan is not the issue it does the same with a shrouded clutch fan. Radiator is brand new. I think the system can't cope with the 125F air temps. Im 4 speed with the 4.30 rear end so the rpm's are high at freeway speeds.
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
This. Turn off your ac and see the difference
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Devin LeBlanc;1754949 said:
IJ, That is about the only thing I don't have. I heard Toyota still has them for like 70.00.. Might end up picking one of those up!
When I worked at Toyota it was around $110 with employee discount. That was two years ago. Nevertheless, completely worth it.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Looking at the diagram in the tsrm it doesn't seem to matter if you cap the lines off. Coolant will still flow at the rear of the head, it's not like it will dead end at the cap. How hot are we talking when you say heating up? I live in Phoenix so I know heat just as well as you do. 220 degrees on the gauge is nothing abnormal. My stock gauge will begin to rise if I drive with the AC on more than about 75 MPH when it is effing hot outside, if I slow down it seems to reduce the load on the engine a lot and temps come down a bit. I have the under tray and all shrouding in place etc with a thick Koyo radiator, and I have a 4.3 rear end too with a W58, so 65mph = 3000 rpm.
It's worth 5>8c @ 65 Mph, not sure what would happen if you kept driving as I always went home and put mine back on or bolted it up properly if the car had been to a shop for work or a bud had "helped with the assembly...
Devin LeBlanc
1,830
Las Vegas NV.
There is a plastic under tray to direct airflow. 95% of old cars don't have them because they were either taken off and never put back on, or broke and fell off in the road.
