Busted ass search....
Doward
4,245
Alachua, FL
Can you believe there are no matches for the word 'won't start' according to the search?
Anywho... I'm starting to get ticked with my car. A little background -
I got the car, starts when warm, but have to try 3-4 times, for 3-4 seconds each, to get her to start when it is cold.
Fast forward past a BHG and generally getting the 7M toward 'new' again, including testing out the CSI, cleaning the CSI, and all is good - car will now start IMMEDIATELY when the car is warm, but still takes 2-3 tries to get her to start right up after sitting overnight.
Now, I've got a MAFT-Pro - the first time I ran it, it fired RIGHT up (video on youtube of it) and I was happy as hell - now I'm thinking the car didn't cool down in the 3 hours or so I took to install it, as I thought. With the MAFT-Pro in SD mode, sitting overnight, this is what I get -
*turn key* Crank crank (1-2 seconds)
*1 second pause*
*turn key* - IMMEDIATELY fires up. Perfectly.
I'm now thinking that perhaps I've got a slightly leaking injector, causing my fuel pressure to bleed out overnight. First second or two of cranking gets the pump going, it repressurizes, and boom - cranked. Time for a fuel pressure gauge :3d_frown:
I'm guessing the best bet will be to bolt a fuel pressure gauge where the CSI injector goes into the fuel rail.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
you could jump the Fp and B+ terminals in the diag box to turn on the fuel pump. then get in the car after the pump runs for a second or two and try to start it. then you could see if thats the problem. easier then installing a gauge.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Could be the CSI time switch. Did you check to see that you have signal to the CSI when its cold?
I also lean towards fuel pressure loss, but I would say that the fuel pump going bad is a more likely cause for the pressure drop.
