busted A340?
sasksupra
prince albert saskatchewan
hey ive never delt with the auto trannys for the supra till now... this is the 4th build ive done and i parked the supra pulled engine and tranny built engine slapped the tranny back on got everything hooked up right and now it will not go into gear? put it in any gear it stays still doesnt do jack shit what could my problem be?
Another MkIII
697
Chicago
Aside from poor grammar, your problem could be many things. Do you have more information? Did it work before pulling the engine, did you service the trans and take a look at the fluid? Did you make sure you got everything hooked back up right? I don't know any specifics about the A340, but we're still at Transmissions 101 with the info you gave.
-AM3
sasksupra
u have to fill the torque converter?... and yes the torque converter is installed all plugs are good and conected right and fluids perfect new filter and gasket, i just need to know the fuck is makin it not shift i have a buyer for it and need it gone fast to start next project..... i did take the torque converter out while tranny was out.... could it be that i put it back in wrong some how?
sasksupra
-AM3
and it drove to were it was parked before i bought it and hauled onto a flat bed to get to my place so im assuming it worked before... kid i got it from was a crack head so hes not exactly reliable thow
The torque converter holds most of the fluid. Yes, it can be installed wrong, and if it's put on dry it can be damaged (if you're trying to drive it). You'll have to keep putting fluid in while the pump hopefully fills it. I've heard of cars that just would not fill the converter though.
Most of the reason you fill it is because it cuts down on time for a repair shop.
8,900
It is better to fill it before. You don't fill it all the way. I don't think the torque converter is installed correctly. Just a guess, I can't see the car from here. Or he has no fluid on the dipstick.
sasksupra
fluid is all good and yea i think i fucked somethin up.... last automatic im buying lol
8,900
Maybe it is just the last time you try something you don't know how to do. You don't do surgery on knees on the side do you?
nofx230
132
Colorado
automatic trannys are picky iv seen a perfectly good working tranny completely stop working just from a fluid change or flush! car or truck drove in the shop and wouldn't even move outta the bay after the change even unreliable (not all but most) shops like midas jiffylube and grease monkey to name a few won't touch a high mileage transmission or a tranny that hasn't had the fluid regularly change because of this very simple fact.
how many miles are on the tranny and how dirty was the fluid that came out?
