Builtmk3's build thread
BuiltMK3
Lurker for Life
Sep 27, 2005
97
CT
empera;878985 said:
very nice sir, think u'll be ready for may? ;)
I hope so. That might be cutting it close.
So i got some grade 8 studs, washers, and nuts to mount my turbo to the manifold yesterday. I removed the exhaust manifold and turbo from the engine and brought them in the house to swap out the crappy grade 5 bolts i had holding the turbo on. I have to take the turbo apart to get at one of the nuts which was no problem. I got all the new studs installed and the turbo bolted down and brought everything back out to the garage. I decided this should be the last time i need to remove the manifold so i would torque all of the nuts down, so i got the loctite and started tightening the nuts. As i got all of the nuts snug i noticed that 2 of the nuts weren't getting very tight. Turns out there stripped :3d_frown:. So i guess my next job is removing the manifold again, and attempting to retap the threads in the head. If that doens't work, guess it's helicoil time. That should be fun. ::hang::
BuiltMK3
Lurker for Life
Sep 27, 2005
97
CT
socc924;882714 said:
Hey man, as long as your taking one step forward and only a half step back, your making progress, haha. I like your "training" arms.
HAHA, oops. I edited it just for you :thefinger.
BuiltMK3
Lurker for Life
Sep 27, 2005
97
CT
So i got the helicoils installed. Only 2 of them were stripped but i figured i should just do them all. I have to admit i was a little nervous drilling into my freshly built head. But once i did the first one it was pretty simple. Here's a pic of one installed.
Next i'm gonna work on getting the brake and clutch pedals and cylinders installed, along with the new brake booster. Since i'm getting rid of the ABS and installing a roll control i need to run all new lines. I was going to make them myself but i just don't see that happening so i will probably end up buying them. Do i have to buy these from Toyota, or is there another vendor i can get them from? Also the bolts that i had to bolt up my clutch were to short so i just got some longer ones so now i can bolt up the pressure plate.
