Build up on my 93 SC300
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
Well guys, things finally have calmed down for me somewhat and I can finally make a post on here. After parting out my MKIII, I came across this car on craigslist, called on it, and picked it up in a couple days. Turned out the car was the daily driver for Chris Johnson (from BoostLogic/Performance Motorsports). Here's what it was like the day I got back from Austin with it.
2JZ-GE - TT headgasket, ARP studs - stock otherwise
BL63 NA-T kit
BL intercooler kit
BL built N/A auto
Re-stalled torque converter
1 of 3 BL SC300 Exhaust systems
AEM EMS
HKS DLI
MKIV TT Brakes F&R
MKIV Struts/Eibachs
MKIV Sway Bars
MKIV Front seats
MKIV Steering wheel
18" SSR Wheels
---------- Post added at 03:06 AM ---------- Previous post was at 02:53 AM ----------
Didn't really do much for a while on it, just a tune up for the first month. Then the built auto setup was killing me (or so I thought) on gas mileage. So I bought a W58 swap from a guy in Houston, and was planning on running it with the boost controller turned out.
But, about 4 days after picking that up, I was catching up with a friend at his Importing company, and ya, ran across a Soarer 1JZ/R154 setup. Bought it on the spot.
Swapped that in and put the 19's off of my brothers 98 Supra on the car.
Also swapped out the 4-spoke style wheel, for the 3-spoke 98 Style out of my MKIII
Took it to the Texas Supras May Meet and tossed it on the dyno, made 366whp @ 11psi (found out I did this on a stock N/A fuel pump, not a walbro as I had been told)
http://www.youtube.com/watch?v=pUoor-tykm4
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
plan for the 1j is to sell it, only bought it for the R154 that came with it, and will be selling that soon as im putting in a v160
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
Here's some of what I've been doing before leaving for SoCal.
Took off the BL 750 I/C Kit
Replaced it with this (took quite a bit of modifying) its the I/C setup off my brothers 98
Also doing up alot of changes to the engine
Billet 6765 DBB
VVTi Coils w/7M CPS
GTE Valve Covers
FFIM/Q45 TB
880cc injectors
Bosch 044 Fuel Pump
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
Havent updated this in a while.
Been driving it around on the new setup for a while now
only at 7.5psi on the wastegate currently, but still runs like a bat out of hell. Just ordered cams from DM, so those go in next weekend. Car even gets better gas mileage now.
Also got a new piece for what goes in to the car in a month. Spec Super Twin disk for the V160 swap
