breaking in my engine
full_thr0ttle
84
Toronto
hey everyone,
just had a quick question..
i replaced some parts in my bottom end over the winter- main bearings and rod bearings, installed ARP connecting rod bolts, front and rear main seals, and added a new oil pump..
and i was wondering.. i did not do such things as cylinder honing or adding new rings, do i still need to break the engine in in a certain manner? if so, whats the best way to do that? if not, am i ok to just drive it normally then?
kirk
HommerSimpson
1,067
New Smyrna Beach Florida
full_thr0ttle;1067251 said:
hey everyone,
i replaced some parts in my bottom end over the winter- main bearings and rod bearings, installed ARP connecting rod bolts, and added a new oil pump..
kirk
if all you did was bearings... just drive it normal for a few miles make sure you did it right. and oil press good to.. then balls to the wall... bearings dont need to seat...
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
HommerSimpson;1067286 said:
pull the ecu fuse and crank over till you get oil pressure...
EFI not ECU ;)
It's in the fuse block right by the battery, it's a big metal 15A fuse, can't miss it.
5
You should have coated the bearing with moly lube to make sure they are properly lubed. Yes they do need a bit of wear in...
full_thr0ttle
84
Toronto
i did put a bit of oil on them before i torqued them down.. ill do wat u guys said and pull that fuse and the plugs and crank it a few times to get pressure before starting it up
