I ask because i have had alot of issues with the CPS wiring, Some times i have to get out and move the wires around for the car to start. That doesnt happen to often though.
I think you just found your problem.suprafanatic;1426173 said:I ask because i have had alot of issues with the CPS wiring, Some times i have to get out and move the wires around for the car to start. That doesnt happen to often though.
suprafanatic;1427492 said:Ok well i checked the resistor and it was pulling 3 Ohms like it was suppose to.
I checked the TPS and it was within specs.
I checked the 3 plugs in the coil pack from the ignitor for good voltage, there fine.
I then checked the CPS air gaps. TSRM says they should have an air gap between .008-.016 ...G1 pick up and G2 pick up were not with in the specs. G1 and G2 were almost touching, i had to use a .004 feeler gauge to fit between them. NE pick up was just fine though. Is .004 to close?
